Veröffentlicht Fri, 07 Apr 2017 17:02:28 GMT von Tim Walsh Solutions Intagrator
I detached databse files and attached the more recent database files to the SQL server. I then copied the Archive files from the old server to the new aerver and updated the archive paths.
On one of my 5 doc types, when I run a browse query, I get a function sequence error when the query runs. The result list then opens. When I go to open the document, the error appears again and then the doc opens.
Any idea what this means and how to fix it or can it be ignored?
I will be migrating the files to Docuware next week and I want to make sure it doesn't cause any issues.
Veröffentlicht Fri, 07 Apr 2017 17:09:00 GMT von Christopher Troester Software Support Analyst
Hey Tim,
Can you try the fix detailed in this article and see if that addresses the issue? If not, please contact us via phone or open a ticket and we will be able to assist you further.
Chris Troester
DocuWare Support – Americas
Veröffentlicht Tue, 11 Apr 2017 12:29:04 GMT von Tim Walsh Solutions Intagrator
That worked.
