Veröffentlicht Sun, 08 Sep 2019 00:50:13 GMT von Doug Mackle VP Professional Services & Security
Question: I need to create a list  with Documents that only end in a specific value.
Business Problem: Client needs to sample every 20th Deal submitted to Docuware
Configuration: I have a workflow that is triggered when a new deal is submitted. I am using an Assign Data activity to store the value of an arithematic expression that divides the DocID by 20 and stores the value to a decimal field. Then I am copying that value to a text field.
I am trying to use a list to return only the documents that end in .00 in the text field with the following where clause like '%'.00, but i am not getting any results.
Veröffentlicht Mon, 09 Sep 2019 14:52:15 GMT von Tim Ohm
The "is (where)" in the 2nd column is actually your "like" qualifier.  So I think just include the value you want in the last column "*.00" should do it.  Not sure if you would need quotes around it - whatever you would use in a search dialog can go in the list definition.
You would only use "%" if using an actual SQL statement.
