Veröffentlicht Wed, 22 Oct 2025 10:19:51 GMT von Thomas Höreth
Hi *!
is there a way to set the filename when printing with virtual printer? We fill our index fields via DWControl and that works as expected.
The documents appear inside the baskets and are correctly preindexed.
Unfortunately our SAP Business One doesn't create usefull filenames and that's why I hope that I can set them via DWControl. Is it possible?
Thank you!
Thomas
Veröffentlicht Fri, 24 Oct 2025 14:37:22 GMT von Thomas Höreth
Solved together with support:
Create a DB-Field "Document Name" and check the button in the last column (file name).
You can fill this field with your desired fiel name via DWControl.
Then the value you've set will be shown and even used when the document is downloaded.
Caution: The target basket has to be bound to the right file cabinet that has the DB-field (here: DOCUMENT_NAME).
With DWControl always use the field names from the database (here: DOCUMENT_NAME) not the names that are
shown to the user at the UI (here: Document Name).
