Veröffentlicht Wed, 20 Jun 2018 18:58:18 GMT von Christen Breedlove Billing
Is there a way to utilize both the web form and the merge form feature in DocuWare? We need to use the merge feature to copy the data on muliptle forms, but also want to keep a copy of the original web form.
Veröffentlicht Wed, 20 Jun 2018 20:59:00 GMT von Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Christen,
The form type is one or the other, There is no option to have both types.
Actually, I take that back. If you want to go to the trouble.
Using Word (for example), create a  document that has the same format as the Web form version. Create a PDF from that document.
In your Form designer, add a second Form to the merge form, and use the PDF that looks like the Web form.
Map your fields to it as you did with the first merge form.
Then when the document is stored it will store both the Merge form, and  psuedo web form.
Veröffentlicht Wed, 24 Apr 2019 19:16:46 GMT von Charles Saad IT Manager
Can we upload a a pdf form that is already created.
It  currently has coloured pulldown list, or can we add colour to our forums or similar to a pdf forum. Similiar to the below chart
de
Veröffentlicht Wed, 24 Apr 2019 20:22:24 GMT von Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
You cannot color individual input areas of the form, but you can certainly overlay the data on to your form.
