Veröffentlicht Mon, 04 May 2020 20:31:05 GMT von Roberto Quintana MCA Consulting Group Americas Corp Gerente de TI
In the past, you could create a filtered profile with SQL statements, but starting with DW 7+, this changed. Is it possible to create one, and use the Fulltext search?
I attach a link to an example of how they were created in the past
https://support.docuware.com/es-es/knowledgebase/article/KBA-35279
Veröffentlicht Tue, 05 May 2020 07:13:27 GMT von Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hi Roberto,
SQL Statement filtered Index value profiles are still possible, however Fulltext Server does not support them according to DocuWare Support.
This means that users who have only an SQL index value profile may use the fulltext search, but will not get any results.
I recently had the same problem and moved from 1 SQL index value Profile to 15 graphical editor index value profiles to get fulltext search to work again.
Veröffentlicht Wed, 06 May 2020 13:17:31 GMT von Roberto Quintana MCA Consulting Group Americas Corp Gerente de TI
Thanks for the reply, I will consider it
