Veröffentlicht Mon, 06 Apr 2020 09:58:16 GMT von Winston Ong Senior Digital Services Consultant
Hello. Good day.
1. Has anyone successfully integrate Docuware with PEPPOL? E.g. with its access points.
https://peppol.eu/what-is-peppol/peppol-transport-infrastructure/
2. If question 1 is not possible, does it mean Docuware have to work with an e-invoicing platform which integrates with PEPPOL?
Thank you.
Veröffentlicht Mon, 06 Apr 2020 09:59:17 GMT von Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Winston Ong! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-124050-N1L8S for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
Veröffentlicht Wed, 09 Oct 2024 11:44:21 GMT von Marc Ilius TDS GmbH Systemintegrator
Hallo Herr Wieland,
gibt es hier schon aktuelle weitere Infos?
Auch ein Kunde von uns hat nach der Anbindung von PEPPOL zu DocuWare gefragt.
Beste Grüße,
Marc Ilius
Veröffentlicht Thu, 19 Dec 2024 12:43:26 GMT von Helmut Holtstiege Consultant
Hallo Herr Wieland,
ich habe auch eine gleichlautende Kundenanfrage.
Beste Grüße,
Helmut Holtstiege
Veröffentlicht Mon, 06 Jan 2025 12:59:07 GMT von Jan Kanters Digital Transformation Enabler
I've setup a Peppol AP (soluz.io) Inbound Inbox import using their (Peppol AP) rest API endpoints
Scenario 1; if the endpoint can forward the invoice and a unique identifier and the customer doesn't want to use make.com
- Invoice (PDF) is forwarded by the Peppol Access Point to a customer mailbox (unique peppol id.pdf)
- Mailbox import from DW (General Email profile)
- DW workflow to retrieve invoice data (UBL) via Peppol Access Point rest api call
- mark invoice as downloaded so it doesn't appear in the Peppol inbox search
Or scenario 2; using make.com schedule scenario
- read Inbound invoice inbox and import UBL data into DW invoice index fields using the Peppol Access Point  rest API
