Veröffentlicht Thu, 18 Jul 2019 23:03:46 GMT von Matt Haslam
2 Questions:
1.  Is it possible to write data back to Microsoft Access with no Match Data? Just simply want to take the metadata in Docuware and transfer it to Microsoft Access. I already have the Microsoft ODBC connector set up and linked with the Local Database connector. They can write info back and forth but only if there is a match.
2. I can only seem to get the Local Database connector to work with the Microsoft Access DB if it is saved in .mdb format and not .accdb format. Is there a way to get it to work with .accdb?
Veröffentlicht Thu, 18 Jul 2019 23:04:46 GMT von Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Matt Haslam! It looks like the Community cannot answer your question. Thats why we have opened a Support Request with the Number SR-72130-T4Z7Y for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have solved the Support Request. With Best Regards, DocuWare Support Team
