Posted Fri, 02 Nov 2018 10:49:25 GMT by Callum McGlynn Technical Solutions Manager
Hi All,
We have a customer that has a requirement to add to a documents index entries the URL for that Document with a dedicated login to be viewed. We need this to output the particular URL for an accounts package to use to display the document.
Any ideas about how we would go about completing that?
Cheers,
Posted Wed, 07 Nov 2018 16:12:44 GMT by Callum McGlynn Technical Solutions Manager
Any suggestions at all?
Posted Thu, 08 Nov 2018 12:54:29 GMT by Craig Heintz SE
Here is a link to the help info for building URLs
http://help.docuware.com/en/#b57862t60280n54814
Also if you search the FAQ site using "URL Integration" at the very bottom are downloadable documents that may help.
https://www.docuware.com/support_faq/
Posted Thu, 08 Nov 2018 13:49:06 GMT by Callum McGlynn Technical Solutions Manager
Cheers for the response Craig.
I'm trying to complete this encoding within WFM to allow one of the index fields for the document to be the fully encoded (With login token) for that particluar documents.
E.g.  https://cloudname/logintoken/fcab/v/DWDOCID
from what I can work out for windows login on the cloud it is fairly straightforward but when you wish to add a login token on the cloud it becomes a little more complex?
