I'm encountering an issue while integrating "DocuWare Platform WebClient" into a WebView2 iframe as part of the development of a Windows Forms (.NET) application.
The purpose of this application is to provide a desktop solution that allows users to launch DocuWare without using a traditional web browser.
Overall, the integration of DocuWare works well, but I am experiencing a problem with the connection to the Desktop Apps.
For example, when I right-click a file and choose Edit, I receive the following message: "Please restart Desktop Apps and try again."
The Desktop Apps are indeed running, since this action works correctly when performed from a regular browser.
Below is my WebView initialization function:
        public async Task InitializeWebViewAsync(string docuWareUrl)
            var env = await CoreWebView2Environment.CreateAsync();
            await WebView.EnsureCoreWebView2Async(env);
            var core = WebView.CoreWebView2;
            core.Settings.IsScriptEnabled               = true;
            core.Settings.IsWebMessageEnabled           = true;
            core.Settings.AreDefaultContextMenusEnabled = true;
            core.Settings.AreDevToolsEnabled            = true;
            core.NewWindowRequested += Core_NewWindowRequested;
            WebView.Source = new Uri(docuWareUrl);
        private void Core_NewWindowRequested(object sender, CoreWebView2NewWindowRequestedEventArgs e)
            var uri = e.Uri;
            if (uri.StartsWith("dwdesktop:", StringComparison.OrdinalIgnoreCase))
                MessageBox.Show($"Open DocuWare Desktop : {uri}",
                                "DocuWare", MessageBoxButtons.OK, MessageBoxIcon.Information);
                try
                    System.Diagnostics.Process.Start(uri);
                    e.Handled = true;
                catch (Exception ex)
                    MessageBox.Show($"Unable to start DocuWare Desktop : {ex.Message}",
                                    "Erreur", MessageBoxButtons.OK, MessageBoxIcon.Error);
Do you have any ideas on how to resolve this issue?
Thank you in advance.
