Posted Wed, 15 Aug 2018 17:33:45 GMT by Roy Slowiak
I have been working with select lists within forms and have noticed that some of the larger select lists get cut off for some unknown reason. Once I noticed this, I exported the CSV where the select list is pulling from and imported it into Excel. This CSV has about 1,300 entries. Once sorting the list from A-Z, I noticed there were only 1009 entries. For some reason, the select list is getting cut-off. This is an external select list.
Is there some type of limit on select lists within forms? If so, is there any way to change such limit?
Posted Thu, 13 Jun 2019 18:33:19 GMT by Nathan French ComDoc Systems Analyst
I have the same question.  The cutoff limit applies in this case to a file connection.
