Posted Fri, 17 Apr 2020 00:33:35 GMT by Josef Zayats
Trying to configure workflow e-mail step with an embedded link (other than to he document itself) with a Link Title (For Example "Click Here"). I thought this should be possible, but which format needs to be used? XML syntax? Has anyone done this?
Posted Fri, 17 Apr 2020 13:07:49 GMT by Josef Zayats
Tried different syntaxes. FInally got it to work with the following simple syntax
<a href=http://website.com/ >ClickHere </a>
Posted Wed, 06 Apr 2022 13:59:24 GMT by Rob Russell
Hi Josef, can you show us the simple syntax that you used? it is a link not showing the syntax in your answer above.
Posted Wed, 06 Apr 2022 14:11:27 GMT by Rob Russell
Nevermind, I found it, thank you. Syntax below. <pre class="linenums prettyprint">&lt;a href="http://website.com/"&gt;ClickHere &lt;/a&gt;</pre>
