Posted Wed, 12 May 2021 13:11:07 GMT by Mark Sandbach IT
I have a workflow set up, it is using indexing from a doc. There are a few places where there is info twice split by a comma.
For example we have me@me.co.uk,you@you.co.uk
or
2 telephone numbers separated by a comma.
Is it possible to set the workflow to ignore all info after the first comma?
Posted Fri, 14 May 2021 09:07:39 GMT by Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hello Mark,
you can use String.Split in an arithmetic expression. There is a Document called "Workflow Expression Parser Documentation" available in the KB or Partner Portal which lists all available expressions.
Posted Fri, 14 May 2021 09:18:56 GMT by Mark Sandbach IT
Hi Simon,
Thanks for your help. I will get the document checked out.
Mark
