Posted Fri, 18 Oct 2019 00:02:33 GMT by Casey Miller Solutions Manager
So, I am trying to move a file cabinet from a server running Docuware at one of our outlying locations. I want to move a cabinet called customer records into another Docuware system on the same network into a cabinet also called customer records. Almost all fields are identical and match. My question, I just want all documents from one server to be moved to the other DocuWare server cabinet. Under synchronization I am seeing Mirror, Synchronization, and custom. What I want to do is to just add the documents from customer records old server to the new server. Keep all files that are currently in the new server but just move the documents from the old server to the new server. I am confused how it is worded. It says all new and modified documents will be transferred one way to target file cabinet. Does this mean any document not modified will not be transferred? I want any document in the cabinet to  be moved to the source cabinet.
I don't want to choose synchronization because I don't want the documents from the target cabinet to move to the source cabinet.. I want all the documents to stay in the target cabinet but also want all of the source cabinet documents to be moved to the target cabinet without any target cabinet documents being changed.
Posted Fri, 18 Oct 2019 00:03:33 GMT by Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Casey Miller! It looks like the Community cannot answer your question. Thats why we have opened a Support Request with the Number SR-112545-Q9Q9L for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have solved the Support Request. With Best Regards, DocuWare Support Team
