Posted Sun, 15 Oct 2023 08:58:09 GMT by Mohamed Saidani SG Software ECM IT Manager
hi,
Is the connection to the Informix database via ODBC possible with DocuWare 7?
Posted Mon, 16 Oct 2023 06:31:04 GMT by Alexander Weber Application Management
Hi, yes we also use an Informix ODBC connection and it works.
Posted Mon, 16 Oct 2023 07:06:27 GMT by Mohamed Saidani SG Software ECM IT Manager
Thank you for confirmation.  Are you using a 64bit or 32 odbc driver?
Posted Mon, 16 Oct 2023 13:41:49 GMT by Tyler Smith Technician Software Support
Up to DocuWare 6.12, we used 32 bit ODBC data sources. With Versions 7+, we use 64 bit data sources.
Posted Mon, 16 Oct 2023 14:07:00 GMT by Mohamed Saidani SG Software ECM IT Manager
For me, 64 bit odbc does not appear in DocuWare Administration because it's 32 bit. can you send me the procedure used?
Thank you so much!
