Publicado Wed, 23 Jan 2019 23:27:31 GMT por Michael Weingand Professional Services Manager
I have a cloud account with Forms and we have a behavior that when a selection = signature, the required, else hidden.  Signature works fine if there is no behavior on it, but when behavior is on, you can not sign in the signature field.  This is consistant.  Has anyone found a solution for this?
https://www.docuware.com/sites/default/files/forums-images/signature_behavior.png
https://www.docuware.com/sites/default/files/forums-images/cant_sign_if_behavior_on.png
Publicado Thu, 24 Jan 2019 20:54:56 GMT por Casey Miller Director of Technical Services
Does unchecking required have any affect? Just curious.
Publicado Thu, 24 Jan 2019 22:34:04 GMT por Michael Weingand Professional Services Manager
Just tried and it does not have any affect.  Still not able to sign.
Publicado Fri, 25 Jan 2019 12:28:12 GMT por Casey Miller Director of Technical Services
Michael, I am testing with on prem V7 with the 12-07-18 install pack. I am not having this issue. I have tried multiple forms. Have you tried using a different web browser? Or maybe tried it on a mobile device?
Publicado Fri, 25 Jan 2019 15:48:22 GMT por Michael Weingand Professional Services Manager
Same behaivior on Firefox and Chrome as IE and Edge.
Publicado Fri, 25 Jan 2019 19:43:42 GMT por Michael Weingand Professional Services Manager
Thanks Casey.  Just heard from support that this is a known bug.  Will be fixed in next update.
Publicado Fri, 25 Jan 2019 21:24:26 GMT por Casey Miller Director of Technical Services
good to know. thanks for the update!
Publicado Fri, 25 Jan 2019 21:31:47 GMT por Matthew Trembly Software Support Manager
I'm just adding that I reproduced this issue in the DW7_2019-01-18 installer also.
Publicado Fri, 10 May 2019 09:01:48 GMT por Marc Wilmington Technical Architect
has this been updated yet?. i have the same issue
