Publicado Tue, 12 Nov 2019 21:47:32 GMT por Phillip Enns Systems Admin
Have a client with a form populating multiple merge forms.  This is with DocuWare Cloud.  It appears changes stopped updating on the merge forms.  Was making multiple changes to the forms and somewhere in the middle it appears to be locked up?   Only half my changes took effect and now anything I add does not show on the output documents.  It shows correctly in the configuration only the output stays unchanged.   Even replacing the merge form file with a new document does not appear to show anything different once output.   Everything stays unchanged but again if I go into the configuration it shows the new document loaded.
Publicado Tue, 12 Nov 2019 21:48:32 GMT por Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Phillip Enns! It looks like the Community cannot answer your question. Thats why we have opened a Support Request with the Number SR-114664-S8J1T for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have solved the Support Request. With Best Regards, DocuWare Support Team
