Publicado Thu, 20 Sep 2018 06:35:18 GMT por Thorsten Dittmar
PLEASE IGNORE THE QUESTION - I NOTICED THAT I CAN UPDATE OTHER FIELDS, JUST NOT THE ONE I WAS TRYING TO UPDATE...
I'm trying to update index fields for an archived document using the .NET API. Following the code in the developer documentation I'm doing the following:
Connect to DocuWare
Get the organization and store
Search for the document by ID
Retrieve the document
Then I execute th efollowing code that assembles the Fields from a dictionary of key/value pairs, which contain an existing field:
Document doc = queryResult.Items[0].GetDocumentFromSelfRelation();
UpdateIndexFieldsInfo ufi = new UpdateIndexFieldsInfo()
  Field = (from kvp in request.UpdatedIndexFields select DocumentIndexField.Create(kvp.Key, kvp.Value.ToString())).ToList()
DocumentIndexFields newFields = doc.PutToFieldsRelationForDocumentIndexFields(ufi);
There is no error when I execute this code, but the fields are not updated either.
Is it possible at all to update the index fields of an already archived document?
Thorsten
Publicado Fri, 21 Sep 2018 07:47:00 GMT por Stefan Kinitz Datatronic Software AG DSC
<ignored>
