Publicado Mon, 18 Feb 2019 12:39:46 GMT por Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Assuming that "Fecha" is a Date Type variable then the problem is likely to be the order of data assignment.
You cannot rely on the data assignments happening in the order you enter them. Never assign a variable and the use the variable in the same data assignment step. Split the data assignment in to 2 or more different steps.
In step one assign the string variable. Then in a seperate step convert the vaiable to a date, then in a final step assign it to the index field.
Publicado Mon, 18 Feb 2019 12:57:34 GMT por Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
No. You are not. You are doing ALL of your data assignments in the SAME data assignment task (step).
Split them up in to SEPERATE data assignment tasks as I indicated.
Publicado Mon, 18 Feb 2019 18:17:23 GMT por Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
There must be some other logic problem. You should open a support request so that we can find where the issue lies.
Publicado Tue, 19 Feb 2019 12:36:56 GMT por Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
It's hard to say. If FECHA is a Date type variable then it should not produce an error. The target Index field is a Date or DateTime type?
Can you expand all of the history and post a screen shot?
Phil
Publicado Wed, 20 Feb 2019 15:03:34 GMT por Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Please open a Support Request. I cannot resolve this in the forum as this point. We have to look more closely at the problem.
