Publicado Wed, 17 Oct 2018 10:18:02 GMT por Craig Heintz SE
In v6 you could schedule the Full-Text extraction to happen a certain times to free up cpu and mempry for production hours. KBA-35463
v7 seems to not have the same settings available.  Is there a new procedure to schedule the hours that Full-Text extraction runs?
Publicado Wed, 17 Oct 2018 10:26:16 GMT por Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Craig,
FT Scheduling was passed over in DocuWare 7. It will be available again in 7.1.
Publicado Mon, 19 Nov 2018 16:00:06 GMT por David Barlet Technical Manager
Hello Phil,
Is it possible at least to reduce CPU usage as we did with DW6.x ?
Best regards,
David
Publicado Mon, 19 Nov 2018 16:33:52 GMT por Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
In the folder C:\Program Files (x86)\DocuWare\Backgound Process Service open the file LongLivingProcessConfiguration.config
At the top of the file is this section:
<process teamImplementation="DocuWare.BPS.Processes.FCDocumentBackgroundTasks.LongLivingProcessEntrypoint, DocuWare.BPS.Processes.FCDocumentBackgroundTasks" moduleName="FCDocumentProcessImplementation" executable="DocuWare.BackgroundProcessService.LongLiving.GenericProcess.x86.exe">
            <taskProcessors>
                <processor limit="4" taskType="0" taskPriority="1" maxFailCount="2" checkPeriod="30" taskTimeout="00:01:00" defaultTimeForProcessing="00:00:10" />
                <processor limit="4" taskType="1" taskPriority="1" maxFailCount="20" checkPeriod="30" taskTimeout="00:01:00" defaultTimeForProcessing="00:00:10" />
                <processor limit="4" taskType="2" taskPriority="1" maxFailCount="20" checkPeriod="30" taskTimeout="00:01:00" defaultTimeForProcessing="00:00:10" />
                <processor limit="1" taskType="3" taskPriority="1" maxFailCount="20" checkPeriod="30" taskTimeout="00:01:00" defaultTimeForProcessing="00:00:10" />
                <processor limit="1" taskType="4" taskPriority="1" maxFailCount="-1" checkPeriod="30" taskTimeout="00:01:00" defaultTimeForProcessing="00:00:30" />
                <processor limit="1" taskType="5" taskPriority="1" maxFailCount="-1" checkPeriod="30" taskTimeout="00:01:00" defaultTimeForProcessing="00:00:30" />
            </taskProcessors>
        </process>
You can limit the processors of these taskTypes by changing the value of processor limit:
0            Image extraction
1            Intellix indexing
2            Fulltext indexing
Restart the Background Process Server.
