Publicado Tue, 22 Jan 2019 15:47:41 GMT por Nathan Werth
I'm looking to default some DW Desktop Printers to Color when printing into DW.
There are no options when going to the printing defaults for the desktop printer.
Where would you need to go to do this?
Nathan
Publicado Tue, 22 Jan 2019 15:54:26 GMT por Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
There is no color or black & white setting for DocuWare printer. It should print the document in the same color depth as the orginal.
Publicado Tue, 22 Jan 2019 17:11:00 GMT por Nathan Werth
Hello Phil,
Yes after more testing, we found that documents were printed in color from everything except from Chrome.
I don't know if Chrome changed something, I haven't heard of this issue from any one else.
I tried it on my PC and I have the same issue when printing from Chrome.  All Documents send to the DW printer are printing in B/W.
Publicado Tue, 22 Jan 2019 17:26:55 GMT por Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Indeed, it appears that Chrome reads the printer properties, and not find a color setting defaults to black & white. I could find a work-around in Chrome so this will need to be reported to R&D for comment. The only work-around at the moment would be to print to a PDF printer and then drag the document in to the web tray.
Publicado Tue, 22 Jan 2019 17:47:37 GMT por Nathan Werth
Thanks Phil, I will update the client that has the issue.
Publicado Tue, 22 Jan 2019 17:50:23 GMT por Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
There is an issue with printing from Chrome. What you can do is to use Printer PS this will print in color from Chrome.
You can download Printer PS here:
 http://go.docuware.com/HFPacks
 Scroll down to additional downloads it should be the second option to download Printer PS.
Publicado Tue, 22 Jan 2019 17:50:27 GMT por Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Publicado Tue, 22 Jan 2019 18:02:18 GMT por Nathan Werth
I gave them this a an option when we first figure out the issue and downloaded it for them.
