Publicado Fri, 06 Mar 2020 11:02:57 GMT por Killian Vaillant
I'm configuring a workflow where users asked me if it can be possible to confirm decision by stamping.
eg: Invoice workflow => instead of using the dialog box, the user approve the invoice by using the stamp.
In workflow configuration there's the option "Decisions can be made using stamps" but i can't find any information about that.
Dose this option fit to my request ?  How can I configure the stamp used in the workflow ?
Thanks for answering !
Best regards.
Publicado Fri, 06 Mar 2020 11:25:15 GMT por Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hello Kilian,
this is exactly what you need. The option "Decision can be made using stamps" enables stamps for this workflow task. The stamp has no extra configuration, it displays the same fields as the form/dialog box.
The only thing you can configure is which fields are actually stamped onto the document. This setting was introduced in 7.2.
See screenshot:
Publicado Tue, 10 Mar 2020 09:29:06 GMT por Killian Vaillant
Thank you.
I can't  do what i want with this but I have a better understanding on this subject.
