Publicado Thu, 29 Mar 2018 16:13:13 GMT por Keith Telford App. Support
We are going to be scanning checks into docuware and would like a watermark on the check so they can not be printed and reused
Is a watermark possible and how this be done.
thanks
Publicado Thu, 29 Mar 2018 16:22:46 GMT por Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
DocuWare WebScan creates a PDF of the document - basically an image encapsulated in a PDF. There is no function in DocuWare to add a watermark. What is possible, is that after the document is delivered to a web tray, a stamp can be applied and merged with the document so that it is a permanent part of the document and cannot be removed. Unfortunately, this is a manual process and cannot be automated. Automation of this can be developed with the Platform SDK by a programmer.
Publicado Thu, 29 Mar 2018 16:40:56 GMT por Keith Telford App. Support
ok thanks i will talk to the business about this as a possible solution ...have a happy easter
Publicado Thu, 29 Mar 2018 16:54:00 GMT por Josef Zayats
Keith,
you could add a predefined image to your checks by configuring Form/Letterhead tab to an import configuration to be used with Docuware scanner, or if you use a different way to scan, such as scan to a folder, the import configuration to be used with an Import Job.
The image from letterhead could be made 'transparent' - this would be pretty much close to a watermark
Publicado Thu, 29 Mar 2018 16:55:52 GMT por Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Josef,
Perfect. I did not even consider that. Nicely automated too.
Publicado Wed, 04 Apr 2018 11:43:48 GMT por Keith Telford App. Support
Would these two options be considered annotations ...if so the users would have the abiltiy to print without annotations ..please advise thanks again
https://www.docuware.com/sites/default/files/forums-images/DWannt.JPG
Publicado Wed, 04 Apr 2018 14:07:00 GMT por Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Josefs method will create a new document with the overlay an indelible part of the document.
My methos IS an annotation but you must MERGE the annotation with the document to make it also an indelible part of the document. If you do not merge then yes, it would be able to be printed without the annotation.
Josef's method is fully automated and is not subject to someone forgetting to merge the annotation.
