Publié Tue, 27 May 2025 09:28:58 GMT par Elias Viera Fernandez DocuWare System Administrator
Hi everyone,
I need to copy the data from the system field "Document Size" (DWSize) into a custom field I’ve created in the file cabinet, using an Autoindex workflow.
However, in the Autoindex configuration, the "Document Size" field does not appear as a source field or as a match field, so I can't map it directly.
Is there a way to do this using Autoindex, without using SQL or external tools? Or is the only option to use a custom query with an external database connection?
Thanks in advance for your help!
Publié Tue, 27 May 2025 09:47:47 GMT par Paolina Lee Document Control Manager
Hi all,
I also have this similar question regarding how to obtain total page count for each document with Autoindex.
Thank you all.
