Publié Thu, 26 Oct 2023 18:47:36 GMT par Mark Massey Cornerstone Building Brands
I'm not sure if this is a technical problem or a configuration issue, so this may not be the correct forum. I modified the LongLivingProcessConfiguration.config file to restrict fulltext operations to after-hours, and I also increased the number of CPUs to be used. The time restriction doesn't appear to do anything and processing resumed right away using more CPU. Has anyone run into this?
Also, what is the difference between Task Type 0 and Task Type 2 described in KBA-36661? The description seems to descibe the same thing.
"taskType=0"= controls the heavy CPU operations for the creation of the text-shots for the documents.
"taskType=2" controls the CPU operations for Full-text Indexing process.
Publié Fri, 03 Nov 2023 00:00:24 GMT par Matthias Wieland Senior Director Support EMEA
Dear Mark Massey! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-215161-V0L3W for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
