Publié Tue, 05 Nov 2024 14:11:31 GMT par Miquel Sanz Vargas Técnico
I'm trying to connect a .xlsx file with article numbers to my articles FC to fill the FC with all that data. I'm trying to do it through the autoindex tool. At the moment I'm trying to set up a file connection using the Docuware Administration but I can't set it up propperly. I set up the file name with the right one and I get an error back. Is there anything I'm missing?
Thanks in advance
Publié Wed, 06 Nov 2024 11:24:59 GMT par Frank Meyer Docuplan GmbH & Co. KG | IT-Leiter
Hello Miquel Sanz Vargas,
at first you should use, or rather you should try to convert your file to CSV format and use this instead of a XLSX file. Maybe this solves your problem.
If not, please tell the community, which error you get back (e.g. by posting a screenshot).
Best regards
Frank
Publié Wed, 06 Nov 2024 11:44:12 GMT par Miquel Sanz Vargas Técnico
Thank you for your quick response, Frank! I was able to resolve the issue by referencing this KBA: KBA-35850.
Now, I’m encountering a different issue. I’m unable to export data from the XLSX file to the FC. I’ve been trying to configure the Autoindex tool, but I haven’t had any success.
Is there a way to extract each row from the XLSX file and assign each row to individual FC input fields?
Publié Mon, 11 Nov 2024 13:08:15 GMT par Frank Meyer Docuplan GmbH & Co. KG | IT-Leiter
Hello Miquel,
it should work if you proceed as follows:
1. Open your XLSX file in Excel, choose "Save as" and save it as a "CSV UTF-8 (*.csv)"
2. Close the file (close Excel)
3. Copy the file to your DocuWare FTP subfolder "data" (ftp://ftp.docuware-online.de/.../data as described in the KBA article)
4. Create a new file connection in the DocuWare Administration
Check if you have set up all column types correctly (they have to match later on with the field types in your file cabinet (a file cabinet text filed must be defined as text here, numeric/decimal as numeric (with the correct subsettings) and date as date) - if your forget to check this or you do any mistakes here, it will not work, because you won't be able to define the matching field in the Autoindex configuration!
Check also, if your CSV-file has column headings in line 1. If so, define this here as well by changing the "Number of line with column heading" from 0 to 1 and also "Start extraction in line" from 1 to 2. Save the file connection and close the DocuWare Administration
5. Create a new Autoindex in the DocuWare Configuration in the correct file cabinet. The index data should be based on this file connection, and the matchcode section should contains all necessary fields which are important here
Best regards and good luck!
Frank
