Publié Tue, 14 Jan 2020 12:07:27 GMT par Markus Greiner
Hi,   Version 7.2.
I created an AutoIndex Job that uses an external Textfile  (Import.csv) and that was supposed to supply already imported documents with more data.
That usually works very well. I have several that I run occaisonally.
Now the Configuration Tab Shows that it is running (läuft).
If I try to STOP it, or try to DELETE it, it turns Grey, and doesn't respond.
Is it possible to manually remove it?
Markus Greiner
PS. I tried changing it, AND I tried deleting the 'Import.csv'  AND Rebooting the Server
it all doesn't work.
Additional Information:
I suspect the cause could be connected to dublicating jobs. In one case I dublicated the job, reconfigured the external Textfile to a new one and the dublicate ran nicely.
Only the orginal wouldn't stop anymore.
Publié Tue, 14 Jan 2020 12:08:27 GMT par Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Markus Greiner! It looks like the Community cannot answer your question. Thats why we have opened a Support Request with the Number SR-118373-W2X4H for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have solved the Support Request. With Best Regards, DocuWare Support Team
Publié Wed, 22 Jan 2020 06:44:40 GMT par Markus Greiner
Thank you for the Help.
Support adds Value!!!
