Frederic,
Good info! I did not know the EMPTY() keyword could be used (or else I did know a long time ago and forgot *smile*).
Just FYI for anyone else reading the thread, you can make the search be for a range of dates by simple adding a second "Value", like this:
<DialogExpression xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" Operation="And" xmlns="http://dev.docuware.com/schema/public/services/platform">
    <Condition DBName="SHIP_DATE">
        <Value>2019-01-01</Value>
        <Value>2019-12-31</Value>
    </Condition>
</DialogExpression>
This is a query on a field called "SHIP_DATE", and would get everything where ship date was in 2019.
For a full date/time field, such as DWSTOREDATETIME, the XML looks like:
    <Condition DBName="DWSTOREDATETIME">
        <Value>2020-01-03T00:00:00</Value>
        <Value>2020-01-03T23:59:59</Value>
    </Condition>
</DialogExpression>
This would get anything stored on January 3, 2020.
Incidentally, you can use the full date/time syntax on a field that is just a "date" type and it works fine. DocuWare stores Date and DateTIme fields the same way in the database (at least in SQL Server).
