Publié Tue, 20 Jul 2021 07:54:56 GMT par Killian Vaillant
Wich configuration is expected by DW with data export  (7.4)?
I want to export datas from standard field (date, numerics, text). I configured the informations i want in my csv but befor saving configuration DW error : "you must set up at least one row for export"
The error stand until i set table export fields. Then I can save configuration but another error on testing : "Export configuration test failed. Processing error in document ID 34975. No table export data was found."
For the moment all the tests made (with or without table field) I have either an error message or an impossibility to save my configuration and therefore impossible to test the export.
Has anyone managed to make it work and if so with what parameters and in what context?
Thanks in advance for your feedback.
#EDIT : Problem solved : The error message wasn't explicit. In fact i only had to set csv heading export informations and everything worked.
Publié Wed, 21 Jul 2021 15:46:49 GMT par Joann Pendleton Data Analyst
But, how did you get around the "you mus set up at least one row for export" ??
I get the same problems you were experiencing.
Publié Thu, 22 Jul 2021 06:33:36 GMT par Killian Vaillant
I join a screen capture to explain.
You only have to set csv header section and data attributions (in my case i didn't need to update fields so i update a field with the same value).
I hope you'll get with. It works very fine when configuration is OK.
