Publié Wed, 12 Jul 2023 11:41:57 GMT par Jojo Goodwin Doctech Application Support Engineer
Is it possible to configure a DocuWare import so that the filename is saved as one of the index entries?
Asking on behalf of a customer.
I don't think this is possible, but I don't see a request for it in User Voice.
Publié Wed, 12 Jul 2023 15:57:47 GMT par Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hi Jojo Goodwin,
you do not find UserVoice requests because it is already a feature, but according to my short search of the help.docuware.com and support.docuware.com pages, it seems like it is not documented anywhere.
I made you a Screenshot from the configuration. First, select the store dialog you want to use, then click on the field you want to fill with the filename. Click on the little "+" icon, select "dynamic entry" and choose "File Name" from the drop-down list.
Screenshot from DocuWare Import Configuration, mapping FileName to an index field.
Publié Thu, 13 Jul 2023 13:19:15 GMT par Jojo Goodwin Doctech Application Support Engineer
Thanks Simon much appreciated!
