Publié Fri, 19 Nov 2021 15:47:45 GMT par Dina Blair Document Management Specialist
We are working on an AP automation project
We are linking documents by PO number
We get all documents back in our search (PO, receiving, invoice and other)
How can we configure this so the customer can open all related documents with a single click?
Thank you
Publié Fri, 19 Nov 2021 16:05:20 GMT par Joe Kaufman Bell Laboratories Inc No longer there
Dina,
Is a third-party custom application an option? You can use the API to gather all documents at once (as PDFs) then combine them into one PDF. We do such integrations via .NET/C# programming.
I am not sure about viewing all at once in native DocuWare. What if some documents are PDF, others are DOCX, and still others are XLSX? What would a "combined" document look like in the viewer?
If they are all PDF, though, they are relatively easy to combine by downloading all PDFs then combining them with Acrobat automation or a command-line tool such as PDFTK. A custom application could also "print" non-PDF documents to convert them to PDF and then combine.
Good luck!
