Publié Fri, 21 Sep 2018 05:49:42 GMT par Jonathan Tinoy Docuware specialist/System Administrator
Hi.
I have a problem in docuware 7 related to fullText Server. I did not install the fulltext server during the installation. when i create a file cabinet, the system display an error that says "FullText Server is not accessible. Please contact your system administrator".  my question is, Is Fulltext Server in Docuware 7 must be installed? if optional, what went wrong? because after i installed Fulltext server, i was able to create a file cabinet.
Thank you.
Publié Sat, 22 Sep 2018 12:28:34 GMT par Craig Heintz SE
I believe full-text is required.  You can run it on another server as it is a resource hog by itself.
Keep in mind the reason this fails is that DW creates all new cabinets with full-text enabled.
