Publié Mon, 29 Jul 2024 16:20:43 GMT par Fran Carrera Lloret Tecnico
Buenas tardes, como se realiza una copia de seguridad de todos los archivos?
Publié Tue, 06 Aug 2024 00:00:29 GMT par Matthias Wieland Senior Director Support EMEA
Dear Fran Carrera Lloret! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-236600-W2L4G for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
Publié Wed, 07 Aug 2024 06:00:00 GMT par Nils Kohl Software Support Team ORANGE EMEA
The following options are available for exporting documents:
1. You can create a request (export) in the DocuWare configuration, in which you can insert the desired documents. You can select the required documents using the filters in the request export configuration. How to create a request is explained in the following article: https://support.docuware.com/de-de/knowledgebase/article/KBA-36401
It should be noted that the files are located in DocuWare's own file structure, which can make it difficult to import the documents into another software.
2. DocXporter exports both documents and index data. The index files can be freely configured using templates — for example, in the preferred format of a third-party application. DocXporter requires an additional license for DocuWare Cloud and for locally installed systems, which entails additional costs. https://help.docuware.com/#/home/94036/1/1
