Publié Thu, 03 Oct 2024 11:18:14 GMT par Sander Helfensteijn
Is it possible to get the email address from a useraccount as a workflow variable?
Publié Thu, 10 Oct 2024 13:58:17 GMT par Jan Kanters Digital Transformation Enabler
Yes this is possible using the endpoint GET Organization/UserByID?userId={userId} of the web service linked to Docuware Platform API
create workflow variable userId_U of type 'user of a group' and assign appropriate use account your want retrieve the mail address
in the request, select the query tab and map the userId field to the workflow variable UserId_U
in the Assign data, select the JSON path (once you've sent a request) $.EMail to workflow variable of type text
Hope this helps...
