Toggle navigation
Forums
Knowledge Base
Status
Downloads
Demandes de Support
Tout
Tout
Pages Web
Forums
Articles de la Base de connaissances
Search Filter
Tout
Pages Web
Forums
Trouver des réponses
Français
Deutsch
Español
Français
English
日本語
Se connecter
Home
Community Forums
Questions about Usage and Configuration
Error trying to compare a GV with an inde field from another FC in Workflow
Publié
Fri, 13 Sep 2024 09:37:09 GMT
par
Miquel Sanz Vargas
Técnico
I'm trying to get the supplier code ( from a FC that is not asigned to this Workflow ) using the following method (see attched file).
I get nothing out of that, it doesn't return anything, like it's not comparing the GV and the index field. I've double-checked and the GV and the index field have the same value.
Thanks in advance
Sin título.png (48,2 KB)
Publié
Tue, 17 Sep 2024 12:36:08 GMT
par
Hi Miguel,
The field DW_NOMBRE is probably a text field. Therefore, its value should be enclosed in single quotation marks, like this:
DW_NOMBRE = 'GV_Empresa'
Publié
Thu, 19 Sep 2024 08:48:19 GMT
par
Miquel Sanz Vargas
Técnico
Thanks! That worked.
But there's something else I want to ask you if you don't mind.
Instead of using "=" it would fit better using "like", sometimes the name isn't equal to the data in our database, I've seen that you have to use "&" and "%". I've tried but I don't get anything but an error.
Obtenir de l'aide
Recherche en Knowledge Base
Demandez à la Community
Nouvelle demande de support
