Publié Wed, 12 Dec 2018 00:46:55 GMT par Raymond Feoli ADP
I will start by saying I am not a programming but technical enough to be dangerous.  I am trying to figure out how to set a routine that loops and fulfills a condition based on a date being set.  The scenario is as follows.
  1. Customer order is received
  2. Order begins processing
  3. Vendor PO is created
  4. Estimated ship date is put into a variable
Its at this point i would like to have a loop where the task is assigned to check shipping status of order but the user is not prompted until the Global Variable GV_EstShipDate = Today.  I have set a Conditional Task that checks for this but my question is if the date does not equal the Estimated Ship date, how do I send it back to check the next day.  So is there a way to execute a task or fulfill a condition using a time function that delays or checks at intervals?
Publié Wed, 12 Dec 2018 07:18:14 GMT par
Hi raymond,
you can send the task after check != today to a task wich escalation time is 1 day, set it to reassign at escalation and send it to your condition check.
that is the easiest loop you can have in docuware workflow
BG
Martin
