Hi Marc,
if I understand you correctly this should be possible. There are two ways of dealing with folder names in DocuWare Import:
	- Decide where to store based on folder name
	In this case you need to activate "Select configuration automatically as specified on "Processing" " on the "Source" tab and then switch to the "Processing" tab to select the area "Identification". You can then select the folder name as an identification option. Additionally the target file cabinet is selected on the "Target" tab.
	- Use the folder name as index entry
	For every index field in a file cabinet you can select the folder name and event the parent folder name. You have to click on the plus icon below the index field and choos "Dynamic entry", then you can choose the folder name.
I hope this helps
Reagrds
