Registrato Thu, 05 May 2016 17:11:22 GMT di Craig Heintz SE
I have a customer that wants to move the Fortis DB to a Hyper V, SQL Cluster from a regulare SQL server.  Will this work or are there things to watch out for?
Registrato Thu, 05 May 2016 17:15:48 GMT di Patrick Seresin Product Quality Support Analyst
Craig,
It is not an environment that we specifically test in. However, as long as the dbs.ini is pointed correctly, and the DB Owner, and logins for SYSADM match, I do not forsee any issues.
Registrato Thu, 05 May 2016 17:35:46 GMT di Craig Heintz SE
OK, thanks.  Will proceed with caution and test before assuming it is OK.  Just wanted to validate if there were any known issues.
