Registrato Sun, 13 Jan 2019 19:40:56 GMT di Cristian Gonzalez Ingeniero de Sistemas
Good day,
I am trying to update docuware from version 6.12 to version 7, the update I am doing in a test machine that is a copy of the production machine, in the step of authenticating with the existing database the system throws the following error: Getting DB Connnections failed. I already checked the dwmachine file and everything is fine. Thanks for the help
https://www.docuware.com/sites/default/files/forums-images/error_0.jpg
Registrato Mon, 14 Jan 2019 13:34:30 GMT di Christopher Troester Software Support Analyst
Good Morning Cristian,
You have posted this inquiry to the Fortis forum, which is a separate product from DocuWare.
If you would like an answer to this question, please open a new support request through our support portal, or submit a new post in the correct forum.
Chris Troester
Software Analyst Support Team FORTIS - Americas
