Registrato Fri, 23 Sep 2016 12:05:25 GMT di David Blake Ricoh USA Sr. Solution Integrator
Changing the Service Configuration > IndexFilePath is simple enough. Is there more move the archive, like within SQL to update file links?
Registrato Fri, 23 Sep 2016 13:02:07 GMT di Patrick Seresin Product Quality Support Analyst
David,
The process is more complex, and requires SQL scripts. I see ou have opened a ticket regarding this issue, please take a look at the email I sent you.
Registrato Fri, 23 Sep 2016 13:02:14 GMT di Patrick Seresin Product Quality Support Analyst
David,
