Registrato Mon, 08 May 2023 12:50:59 GMT di Ashton Maevers Technical Application Support Analyst
Morning all!<br> I am seeing a lot of information about the 7.8 update but am not seeing the download for it anywhere? Is it out yet or do we have a release date for it? We are looking to upgrade and if it's within the next week or so we may wait to use that instead of 7.7.&#160;<br> Thanks for any info!<br> Ash
Registrato Mon, 08 May 2023 13:06:10 GMT di Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hi Ashton,&#160;<br> <br> the download is currently only available for ADPs in the Partner Portal and Partner Info. It will become publicly available next month.&#160;<br> <br> Hope this helps.<br> <br> Greetings from Germany,<br> Simon H. Hellmann<br> DocuWare System Consultant
Registrato Mon, 08 May 2023 13:08:42 GMT di Ashton Maevers Technical Application Support Analyst
Ah that would indeed do it! Thank you Simon for the swift resopnse.
