Registrato Mon, 14 May 2018 14:47:49 GMT di Todd Priest Support Manager
I have a customer that has SQL server for there DocuWare system. They need to implement a DR system. They would like to use SQL replication. Has anyone ever set the DW piece up? Just looking for some kind of direction to accomplish this.
Todd
Registrato Mon, 06 May 2019 02:06:51 GMT di Jon Weston File IT Solutions Sr Application Developer and RIM specialist
Hi Todd, I'm in the same situation now.  Did you receive any recommendations? How did you proceed?  The DW system I'm setting up will be on-prem and won't be featuring a high influx of documents - more like a sporadic-but-scheduled import of scanned documents - and also won't be seeing a large number of data updates.  So I'm thinking that automatic fail-over protection won't be necessary.
