Registrato Wed, 19 Jun 2019 12:31:27 GMT di Kim Sims Technical Solution Architect
I have a new DW 7.0 system that was installed yesterday. After install completed and subsequent system restart, I was able to log into the web interface successfully, however, when attempting to create a new file cabinet, I receive the message that 'Fulltext Server is not accessible. Please contact your system administrator'.
I can see that the fulltext service is running and it will restart without issue. To troubleshoot, I disabled the firewall and restarted the system with no change. I then opened the installer directory and located the fulltext server, right clicked and uninstalled. I then reinstalled it, but, saw the same results. I actually uninstalled and reinstalled it a couple times, to no avail. I wasn't seeing an error in event viewer directly related to the fulltext server.
The rest of the system seems to be functioning correctly.
I'm not sure what to try next.
Registrato Thu, 20 Jun 2019 22:27:44 GMT di Kim Sims Technical Solution Architect
Nobody has a reply, even DW support?
Registrato Fri, 28 Jun 2019 21:01:59 GMT di Kim Sims Technical Solution Architect
This was resolved once it was discovered that the DW installation routine did not populate the fulltext port to be used in the admin tool fulltext server path. Once that was in place, it began to work.
