Registrato Wed, 10 Nov 2021 21:37:42 GMT di Kim Sims Technical Solution Architect
I have a client running v7.4 with extensive use of result lists.
Their lists are not dynamically updating when a document is modified and should be reflected in the list. The only way it displays is for the browser to be refreshed.
There is an option for the result list, under more options, to 'Refresh Automatically'. I've changed it, saved and re-enabled it but, it did not make a change in behavior.
I've since stopped the DW services and cleared the msg bus. After asking the client to perform some testing, she is seeing the same issue.
Server is going to be restarted after hours.
I see that v7.5 has an option to modify the refresh interval. Is there an ini file buried somewhere that might accomplish the same thing?
Registrato Wed, 17 Nov 2021 21:37:42 GMT di Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Kim Sims! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-164623-B9Q0C for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
