Registrato Fri, 11 Jul 2025 11:40:34 GMT di Chema Lopez Developer
Hi.
I would like to see a fully working CheckInFromFileSystem example in REST API.
I am using Spring Boot with a RestTemplate. I convert CheckInActionParameters to JSON but I haven't been successfull. I have tried to conver to XML with any luck either.
This is the JSON I send:
{"$type":"CheckInParameters","DocumentVersion":{"Major":1,"Minor":10},"Comments":"New Version","CheckInReturnDocument":"CheckedIn"}
This is the response I get:
The checkInModel field is required.
Thank you in advance.
Registrato Fri, 11 Jul 2025 11:43:21 GMT di Chema Lopez Developer
The Postman collection refers to some files that are not available:
Registrato Fri, 11 Jul 2025 11:43:54 GMT di Chema Lopez Developer
Registrato Fri, 11 Jul 2025 12:14:57 GMT di Chema Lopez Developer
I finally did.
It seems that I forgot to set the Content-type of the JSON part.
