Registrato Tue, 13 Aug 2019 19:17:36 GMT di Steve Shriver Application Specialist
A customer has used the Index Cleaner to combine similar names into one preferred name (V6.10). The cleanup of the actual index values was successful but it appears that the standard select list was not updated (different table?).
Is there a way to force the update of the select list?
Registrato Tue, 13 Aug 2019 19:18:36 GMT di Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Steve Shriver! It looks like the Community cannot answer your question. Thats why we have opened a Support Request with the Number SR-73889-K5M3H for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have solved the Support Request. With Best Regards, DocuWare Support Team
