Registrato Mon, 05 Jun 2023 13:02:10 GMT di Adam Atkins
Hi Team,&#160;<br> <br> We are looking to get the FIle/Document folder path using API. We couldn't find there is&#160; a direct property to fetch the file/document folder path. Please help us how to fetch the folder structure path for the docuemnt.
Registrato Mon, 12 Jun 2023 08:18:44 GMT di Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hi Adam,<br> <br> getting a folder path via API is not possible, because there are no folder paths in DocuWare.<br> A folder structure just <em>displays</em> documents in folders which represent index values.<br> However, you should be able to retrieve the values for all index fields of a given document.<br> <br> Hope this helps.<br> Greetings from Germany,<br> Simon H. Hellmann<br> DocuWare System Consultant
