Registrato Fri, 04 Oct 2019 18:20:11 GMT di David Moore Co-Contract Administrator
I have run into issues attempting to force windows updates on various versions of windows servers. I have discovered if you remove the Windows Desktop Experience Role/service the updates will then download and install on demand. I have done this on a new server without Docuware installed. If I remove the service on a server hosting docuware will it impact the operation or break the system? I believe this role is assigned when DocuWare is installed. Servers need updating before the installer will proceed. This has prevented upgrading in the past.
Registrato Fri, 04 Oct 2019 18:21:11 GMT di Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear David Moore! It looks like the Community cannot answer your question. Thats why we have opened a Support Request with the Number SR-111539-L8D1K for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have solved the Support Request. With Best Regards, DocuWare Support Team
