Registrato Fri, 23 Feb 2024 10:26:18 GMT di Virginie Chardet
Hello when we try to log in to docuware , we have the redirect page that doesn't succeed
Registrato Fri, 23 Feb 2024 13:38:32 GMT di Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hello Virginie Chardet,
please check the Link you are using for Login.
You probably saved a link to https://login-emea.docuware.cloud/ to your favourites, desktop or whatever you use to store your links.
Your link should just be https://pelletier-tp.docuware.cloud/
This not working redirect usually occurs when you are using a wrong URL.
