Registrato Thu, 09 Sep 2021 07:49:33 GMT di Chema Lopez Developer
I have analyzed the HTTP calls involving a Form. I want to replicate them wihout using the HTML form provided by DocuWare. But the server gives a 500 error.
<?xml version="1.0" encoding="utf-8"?>
<?xml-stylesheet type="text/xsl" href="/DocuWare/Forms/Content/errors.xslt"?>
<s:Error Uri="http://ORGANIZATION.docuware.cloud/DocuWare/Forms/Submit" Method="POST" StatusCode="500" Status="Internal Server Error" xmlns:s="http://dev.docuware.com/schema/public/services">
    <s:Message>Object reference not set to an instance of an object.</s:Message>
    <s:Exception>System.NullReferenceException: Object reference not set to an instance of an object.
I think some cookies or parameters are missing but I would like to know if there is a simple guide to do that or I will have to do more research of the HTTP calls.
Registrato Thu, 16 Sep 2021 07:49:33 GMT di Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Chema Lopez! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-159744-S7L2S for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
