Registrato Fri, 28 May 2021 07:49:39 GMT di Rhys Woolley Software Developer
In the Workflow Designer, I have a Task with the dialogs "Document Type" and "Sales Person", these might as well be placebos for now. The user the task is assigned to can fill in these fields on Docuware. So far I have them saved to a GV. I want to know if there is a way to map the information on the task (or the GVs) and have it mapped to another form, which will then be published and kick off another workflow?
Registrato Fri, 28 May 2021 07:51:07 GMT di Rhys Woolley Software Developer
Sorry, I should add that this workflow is kicked off by another form, so the Workflow will be started with one form and will end with the submission of another, which will begin another workflow
